HI! I've change my build because I found out that Ryzen is better than i7 for my editing PC. Check out the part 1 of this thread: http://www.tomshardware.com/answers/id-3403067/final-build-compatibility-check.html
I changed the processor, motherboard, and GPU from the previous part. Others remain as is.
Case- Antec 100 Mid-tower case ~(This case is my old one and I'm not planning to change it. However, I search that this case doesn't have a USB 3.0 in front but the motherboardn that I'm gonna buy have it, what options do you guys have?)~
Motherboard- MSI B350 Tomahawk Arctic ~(I chose this board 'cause it's compatible with the processor)~
Processor- Ryzen 1700 ~(I think this processor is good for my editing PC)
RAM- G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 ~(Well, I don't understand the name that much but that's what my friend recommend me. Is this good?)~
GPU- ASUS ROG Radeon RX 480 STRIX-RX480-8G-GAMING 8GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card ~(Is this compatible with my other components? Another issue I have here is that the Asus doesn't have a VGA port and my monitor only has VGA, what should I do? Consider the performance please)
HDD- I'm gonna use my old 1TB HDD here if that's ok. Is it?
PSU- My friend recommend this three power supply: Seasonic S12II-520 ~OR~ Seasonic M12II-520 EVO ~OR~ Seasonic G-550 ~(Which is better? Is this three have enough power to run my system?)~
CPU Air Cooling- I'll just use the stock cooler of Ryzen 'cause I don't have a plan to overclocking my processor
Monitor- Samsung SyncMaster B1930 ~( This is my old one. Like I said above, it only has VGA port)~
So that's it, tell me if I forgot something. Please consider everything in every part. Tell me if there's any incompatibility in this build. Thank you for your time and have a great day! You can recommend other parts too!
