Items Purchased already or that I already own:
21.5 Inch Acer 1080p monitor
XFX Radeon 5770 1GB
500 GB Caviar Black SATA Hard Drive
CM Storm Sniper Black Edition Case
Asus DVD-RW Drive
Pretty much set on the power supply and cpu, unless i can save some bucks on the power supply, but i dont wanna cut a corner if i decide to over clock down the road.
CPU:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX
PSU:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
These two mother boards look similiar but which is better? Say for overclocking and everything that i would need? Are these good brand motherboards or? I am probably going to crossfire two 5770s down the road.
Motherboard:
ASRock 880G EXTREME3 AM3 AMD 880G HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
or
ASRock 870 EXTREME3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
RAM:
These sound the same so im a lil confused here.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
or
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
Also will the cpu come with a cooler and heat sinks and will those be sufficient for stock speeds and some overclocking?
XFX Radeon 5770 1GB
Asus DVD-RW Drive
CPU:
PSU:
Motherboard:
or
RAM:
or
