first I would like to thank everyone who has helped me (mostly agera one and mickeyphoenix).
ok im making a computer and it needs checking that everything will work together (hardware and software).
parts list
intel 5 4690
thermaltake r21 case
WD 1TB 7200rpm blue
Kingston 60gb ssd
win/8.1 64 bit
gigabyte h97 gaming 3
gigabyte r9 280 OC 3gb (non 'x' version)
Kingston hyperX fury blue 2x4 gb ddr3 1600 MHz (theres other info on this if needed)
antec hcg-620m 620w high current gaming psu
coolermaster jetflo 120mm blue led
thermaltake black case fan 120mm
(please give me info on if the fan speed is changeable if the led light can be turned on or off and if the whole build will fit and work together).
THANKS please reply if you need more information!!!
parts list
intel 5 4690
WD 1TB 7200rpm blue
Kingston 60gb ssd
win/8.1 64 bit
