Hey Everyone,
First time builder here.
I want to build a PC primarily for gaming, streaming, video editing. I have a build in mind, but being this is my first build any suggestions will be welcomed.
Please let me know if there is anything else I will need or if certain parts don’t work well together. The budget I have is between $1500-$2000.
If you have suggestions please explain why, I would like to learn as well, please don’t just make a build for me.
The build I have in mind is:
CPU: Intel Core i5-4690K
MOTHERBOARD: MSI MSI Gaming Z97 GAMING 5 LGA 1150 Intel
MEMORY: CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3
STORAGE: SAMSUNG 850 EVO 2.5" 120GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E120B/AM
STORAGE: WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZEX
VIDEO CARD: MSI Radeon R9 390X DirectX 12 R9 390X GAMING 8G 8GB 512-Bit GDDR5 PCI Express 3.0 HDCP Ready CrossFireX Support ATX Video
CASE: APEVIA X-TROOPER Series X-TRP-RD Black/Red Steel ATX Mid Tower Computer Case
POWER SUPPLY: EVGA SuperNOVA GS 220-GS-0650-V1 80 PLUS GOLD 650 W ECO Mode Fully Modular NVIDIA SLI Ready and Crossfire Support Super Silent Continuous Power Supply
COOLING: Enermax Liqtech 240 All-in-One Liquid Cooler 27MM Thick Radiator w/ Duo High Pressure Airflow Fans
Monitor: BenQ 144Hz, 1ms High Performance 24-inch LED Gaming Monitor, 1920X1080(XL2411Z) (Eventually want to run triple monitor set up)
I will eventually want to overclock this set up. However, do I have enough cooling to run it at a safe temp (I know it wont be exact but just based of the cooling system), would I need more?
Also, for the case, if someone can tell me if all the components would fit in that case size or would I need a different one?
As noted above I eventually would want to run a triple monitor set up. Will the GPU I chose be able to handle it? Some games I would want to use all three screen some games only use one.
Games I play are COD, Witcher, Fallout 4, GTA5, LOL, racing games, sports games.
I want to be able to play on MAX settings.
I am looking at parts on newegg.ca, amazon.ca.
Thanks in advanced for everything.
