finally gonna do my first build need advice
bighawk25
17
planning on building a pc with these components. just wanted to make sure they will all work together and that i wont run into any problems. also anything i should look out for when buying or building using these parts.
case: nzxt phantom 410 mid tower usb3.0 gaming case
motherboard: asus sabertooth z97 mark1
cpu: intel i7 4820k
gpu: gigabyte gtx780 gddr5 3gb OC
ram: corsair vengeance 32gb (4x8) ddr3 1600mhz
psu: corsair professional series 860 watt digital atx/eps modular 80 plus platinum ax860i
ssd: samsung 840 pro series 128gb
hhd: seagate barracuda 3 tb 6gb/s 7200rpm
corsair hydro extreme performance liquid cpu cooler
os: windows 8.1 pro 64 bit
also do i need more fans in case now or is it optional?
i think thats everything. thanks in advance guys
