Hi there all.
Nightmare Dancase A4SFX build with an asetek 545.
Just got it running great after many issues. Ran it at idle for 5 days straight to download programs/steam and to test for heat build up in the case and fan bearing flex issues (trust me its been a problem). Temperatures where excellent. no issues.
Then rebooted to install all of the programs properly and played crysis at 165 no issues.
Shut it down to give it a rest. About an hour later went to boot again and no response. Leds on motherboard where still on indicating no issues with power from house to motherboard .
Thought this must be an easy fix because cable obstruction of the power button and 2 pin disconnection has been a common problem due to cable.management and it having no clips.
Opened it up and no cable obstruction button seems to be working fine on case and the little button board
Checked the 2 pin. Its definitely in the right place and is all the way in. Has a little flex on it though which has me worried but I remember being normal. Saw a little dust on the cable connector so I blew that out.
My thoughts so far -
1- Broken power io 2-pin on the mobo 2 - maybe still dust bridging power and ground on 2pin cable
3 - button board stuffed
4 - Power supply gone but I doubt it .
5 - optane somehow
Serious considered help would be much appreciated.
Cheers
atlas
Dan Case A4 v2 SFX Chassis
Asus Turbo Edition 1080 Ti
Intel i7 8700K Coffee Lake 3.7Ghz
Hyper X Fury Black Edition 2x16GB DDR4
ASUS Z370I ROG STRIX
Intel Optane 800P 118GB NVME M.2
Samsung 960 EVO 1TB NVME m.2
Seagate Barracuda 5TB ST5000LM000
Asetek 545LC
Philips 272S4LPJCB 27in QHD LED Monitor
Acer XB271HUA 27in WQHD G-Sync 165Hz
Silverstone SX650-G SFX 650 Watt
5 - optane somehow
Cheers
atlas
Asetek 545LC
