I have this front panel:
www.cmstore.eu
A cable is broken so one USB doesnt work. I was looking to replace the panel with a similar one but that has 2 USB 3.0 ports, however I cannot find any. in fact, looking for "front panel" gives me those 5" bay panels instead of this.
Note that it has 2 USBs (1 3.0), 2 audio and 1 SD card. Its embedded in the front panel case, so that part cannot be replaced...
Do you know if its possible what I want?
Thanks you
Silencio 450/550 USB Card (new version)
Welcome to the official Cooler Master store - Browse for accessories, spare parts and peripherals. Customize, Upgrade and Adjust to Make It Yours!
Thanks you
