Question Finding compatible LCD replacement
jzeds1491
21
Hi guys, I'm looking for lcd replacement that fits on my Alienware M14XR1 laptop, so far I could find Samsung LTN140KT08-801 (specifics match 14inch 1600*900 40pin) but the one on my laptop is Samsung LTN140KT05 D01 .
As I said specifics are identical but only codes are different .
So will it work on my laptop? Can you understand the code?
(P.s. Can't buy from ebay alibaba etc)
LTN140KT08-801
http://uupload.ir/files/4r94_13009025-1-1000x1200w.jpg
http://uupload.ir/files/93e2_13009025-3-1000x1200w.jpg
LTN140KT05 D01
http://uupload.ir/files/bm7_10693_59847.1567577321.1280.1280.jpg
The back end of your displays have connectors on them, the one that seems to be a replacement doesn't have the connector in the middle bottom end of your screen. While disassembling the laptop, did the lower connector connect to anything on the board/laptop?
This is my screen, pins are like the replacement (40pin connector lying down)
Also the cable is connected to board directly (can't make sure)
