Ok, so here is my build:
PCPartPicker part list: http://pcpartpicker.com/p/tnwK23
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($169.99 @ Newegg)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler ($69.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($114.00 @ Newegg)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory ($154.99 @ Newegg)
Storage: Crucial M500 240GB 2.5" Solid State Drive ($109.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($53.99 @ Newegg)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card ($369.99 @ NCIX US)
Case: NZXT Phantom 410 (Gunmetal/Black) ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($102.98 @ Newegg)
Total: $1261.89
These questions will mainly deal with issues related to the power supply/motherboard and case.
1) I moved the rear fan on the NZXT Phantom 410 to the top, as my cooler fan would be replacing that one. So I have in total the cooler fan, two top fans and a front fan. The cooler fan and top two fans both run, but the front fan does not! I'm pretty sure I have all my cables routed into a molex for the fan controller, but I am not sure if I did it correctly. I did NOT plug anything into the sysfan1 or sysfan2 spots on my MOBO, as there wasn't anything to plug in (the fans were already plugged in to receivers, leading to the fan controller I believe. The cooler fan I plugged into the "power fan" slot. Why isn't my front fan working?
2) The fan controller does not change the fan speed. Currently only one of my fans lights up (I was certain the front fan had an LED also, but maybe whatever is causing that fan to not work is also causing the LED to not work either. Adjusting the fan controller on the case causes no change to fan speed, however it does slightly increase/decrease the brightness of my one fan LED. Very weird...
3) No firewire 1394 (I believe those are the numbers, laziness.) I'm assuming my power supply doesn't support that, as it is not modular so there's no way I could have lost a cable. Do I need a firewire thing anyways?
4) How do I get my computer to detect my hard drive? I unplugged the hard drive so my computer would automatically download the OS to my SSD (that's what newegg told me to do :/) but then after plugging the hard drive back in my computer doesn't recognize that it is there. What do I need to do?
I probably will have a couple more questions but these are the major ones right now. Thanks for all the help, I'll post pictures when I can if those will help
Total: $1261.89
