I have an aorus z390 and I have been messing around with the rgb functions with the fusion app. I had connected my 3 case fans which all share an RGB header to the RGB header on the motherboard and everything seemed fine. The fans defaulted to green and I went to change the color in the fusion app a few hours later. Once I selected the option to change the colors they started alternating and when they got to yellow I saw a flash thru my glass side panel and then a flame and smoke where the rgb header was. I quickly yanked the power cord and nearly had a stroke. After The smoke cleared I opened the case and found that a small transistor or fuse above the rgb header looked burned. I unplugged the rgb headers and turned the pc on and it seemed to work fine except for the 3 case fans being stuck on blue and flickering and the motherboard's rgb no longer working and the fusion app refusing to start. I got a new mobo just to be safe and RMA'd the old one. What could have caused this? bad case fans? the fact that 3 fans shared a single header port? the fusion software? I did just install a new thermaltake 850w psu that night so could it be that? Some reviews of it have people claiming it "fried their system" But this only occurred when I was cycling the colors of the fans and I am still using the same PSU and everything is working fine now. Here is a link to a pic of the damaged area. https://ibb.co/3WKtHkq
