Hi Everyone,
I need a bit of help
I was just curious and wanted to see what that PC looks like inside. Unfortunately when I took out the motherboard, a plastic piece of the power button (the one that was touching the button on the chassis) snapped. Now the piece that is left inside doesn’t move, I assume it’s stuck in “pressed” position.
From what I can see, that entire button is integrated with LED light, there are 5 pins on the other side of the motherboard. What are my options? Is it possible to leave that button to not go into soldering on the motherboard and just solder something into that existing one? Or do I have to remove it completely?
The hole in the chassis is 9mm wide, maybe I could remove the existing button, solder two cables onto the motherboard and install a totally new power button into that 9mm hole then connect with those cables?
How to measure those 5 pins to find pins that are responsible for powering up? I assume, once found, that I can just short them just like 2 power pins on standard PC motherboards when I was using a screwdriver to power up bare motherboard?
Thank you for all suggestions.
Here is the link to all photos - https://ibb.co/album/PzLwmM
Regards
Regards
