Hello All,
I just upgraded to Gigablast in my area. The service provider installed a Netgear R6300 (AC1750) at no cost. It replaced a Belkin AC 1200 DB Wi-Fi Dual-Band AC+ Gigabit Router.
Problem: I can no longer Remote Desktop from my wireless Laptop to my wired Desktop in another room with the new Netgear router. I could with the Belkin router. As a matter of fact, I still can with the Belkin if I unplugged the Netgear and reinstall the Belkin. I already validated the switch back to the Belkin router, and ability to Remote Desktop from wireless to wired, to eliminate both computers settings, software, updates, etc. Another tidbit, I can ping from one computer to another on the wireless side or on the wired side with the Netgear router. I can't ping from wireless to wired, or vice versa, on the Netgear router. I only want to be able to Remote Desktop from within my home, nothing outside of network.
I already called Netgear and unfortunately after 30 mins was told that I need to subscribe to a 6 month or 1 year maintenance program in order for them to help.....
I think it is something fairly simple but beyond my capabilities so a posting on Tom's Hardware should do the trick.
Thanks in advance!
The guest login is disabled. The firmware is up to date. It is unfortunately customized firmware from the provider, cox, loaded onto the router. I don't see any setting for wireless isolation on the R6300 either. I guess I could just set up the Netgear R6300 as another Access Point by just plugging it into the back of the Belkin AC1750 and use the Belkin for the wired desktop that I want to remote access into via wireless on my laptop and have those to hooked up to the Belkin. It would be a work around but would be clutter having both routers working at the same time.
Thanks in advance!
