firewall problem please help
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
dear Robert:
as i checked the event viewer the error source was service control
manager,and the error number was 7023.kindly reply me for what should i do
now??
regards,
"Robert L [MS-MVP]" wrote:
> select OK. if you get an error, check the event viewer and post back with the error.
> Bob Lin, MS-MVP, MCSE & CNE
> How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
> Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
> This posting is provided "AS IS" with no warranties.
> Don't send e-mail or reply to me except you need consulting services. Posting on MS newsgroup will benefit all readers and you may get more help.
> "Ahmad Al-Nahar" <AhmadAlNahar@discussions.microsoft.com> wrote in message news:83EE1106-48C8-4AD5-A538-54545AF6005A@microsoft.com...
> dear all:
> when i try to operate the firewall service the following message appears:
> "windows firewall settings can not be displayed because the associated
> service is not running .do you want to start windows/firewall (ICS) service??
> ok cancel
> please note that i have win xp sp2 and norton antivirus 2005 installed on
> my computer and i use ADSL 1.2 Mbps line.
> kindly help me to make my firewall on .
> regards,
Was this post helpful to you?
G
Guest
Guest
'When you disable the Windows Firewall service on your Windows XP
Service Pack 2-based computer, the Computer Browser service stops after
five minutes and Event ID 7023 is logged in the Event Viewer'
http://support.microsoft.com/?kbid=889320&SD=tech
regards,
ssg MS-MVP
Ahmad Al-Nahar wrote:
> dear Robert:
> now??
> regards,
>> dear all:
>> ok cancel
>> regards,
