First Boot/Build. Blank Screen
pkfir3
Hey everyone,
So I'm trying my hand at building a computer and everything went smoothly up until the first boot. First, my front power button isn't working so I'm using the power button on the Mobo. Computer turns on fine, all fans work. There is no input on my screen however. I'm using a DVI cable from my graphics card to the monitor if anyone is wondering. I tried the sticky on first boot/input problems, everything seems to be in order. Any advice would really help me out. I just want to play some games!!
CPU: AMD FX-6300 3.5 GHz
Mobo: Asrock 970 Extreme4
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card: XFX Radeon HD 7950 3GB
Case: Corsair 300R Window
Power Supply: SeaSonic 550W
Hi, if you can list all of the parts you used in the build.
Cpu: Brand, model number
Motherboard: Brand name, model number
Memory: Type and speed
What Graphics brand and model.
Pci-e card or on board video of motherboard.
Also list the brand of the power supply and its wattage.
