Hello All,
I'm putting together my first build and would appreciate your thoughts. I'll use this build for web development and gaming. One "unique" goal - I want to triple boot Windows/Mac/Linux as I prefer to develop in Mac/Linux and game on Windows. I've research what it takes to do this and I think my build meets all the requirements. Overall, I want to get the biggest bang for my buck in terms of performance and longevity; I plan to keep this setup for 3-4 years or longer if possible with upgrades.
Approximate Purchase Date: May 2012 (After Ivy Bridge release - hoping to see drop in Sandy Bridge prices )
Budget Range: $1000 +/- $100 before rebates, cheaper = better
System Usage from Most to Least Important: Software (Web) development, Gaming (Diablo 3, SC 2, BF, Skyrim, etc), Photo Editing, possible engineering modeling later
Parts Not Required: Keyboard, mouse, monitor, speakers, OS, HDDs (I have 1 TB for storage, x2 500 GB for Linux and Mac OS)
Preferred Website(s) for Parts: Newegg, Amazon
Country: USA
Parts Preferences: by brand or type: Hardware verified to be compatible with Windows/Mac/Linux (Intel processor most important)
Overclocking: Yes
SLI or Crossfire: Maybe, later (if I do go this route, I would want to upgrade my PSU at the same time, so the PSU selected is NOT for SLI/CF)
Monitor Resolution: Dual 1920x1080 monitors
Additional Comments: Quiet and not "flashy" - case and noise level should be appropriate for an office setting... Still want something that's solid and looks good though
Here's what I have so far:
Newegg Wishlist
Also listed here for convenience:
CPU: Intel Core i5-2500K ($220)
CPU Cooling: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler ($30)
Motherboard: GIGABYTE GA-Z68XP-UD3 ($150)
GPU: EVGA 012-P3-1570-AR GeForce GTX 570 ($300)
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) ($47)
SSD: Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) ($90)
PSU: CORSAIR Enthusiast Series TX650 V2 650W ($90)
Case: Antec Three Hundred Two ($70)
Optical: ASUS 24X DVD Burner ($20)
Misc:
[strike]Arctic Silver 5 Thermal Compound - OEM ($10)
[/strike]Edit: As a few of you have pointed out, the Hyper 212 comes with a good thermal compound.
Total cost: ~$1017
Any general thoughts? Thoughts on Mobo/GPU/PSU/SSD? Anything I'm forgetting - cables, fans, etc - that I'll need during assembly?
Thanks again!
Country: USA
Overclocking: Yes
Newegg Wishlist
Misc:
Total cost: ~$1017
Thanks again!
