First Build Advice Needed!
I assumed so, but 3000rpm is insane! try Corsair SP 1450rpm fans.
Tips...get different fans. Those Noctua fans are great but if you push them beyond 1500rpm they will get really loud. Second, get a i7-7700k. It helps when you have a high end GPU. Otherwise...great build!
The Zotac AMP is really good and the Windforce as well.
The fans would be replacing my radiator's stock fans
