Approximate Purchase Date: Now
Budget Range: ~1100 after rebates. I am flexible. More concerned with value and quality over cheapness.
System Usage from Most to Least Important: Gaming, Adobe Creative Suite, Everything else
Parts Not Required: keyboard, mouse, speakers, monitor
Preferred Website(s) for Parts: whatever is cheapest. I have $250 credit at amazon I would like to spend ( probably will just use it on the processor)
Country of Origin: US
Parts Preferences: by brand or type: Intel
Overclocking: Yes
SLI or Crossfire: I would like to have the option for dual cards down the road.
This is my first build. I have no idea what I am doing but I have been doing a lot of research. Here are the parts I have picked out so far. Feel free to laugh at my uninformed rookie decisions.
Processor: Intel Core i5-2500K Sandy Bridge 3.3GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
219.99
Mobo: MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574
149.99 after rebate
Theres lots of MOBOs that look almost identical. Need some advice.
DVD Drive: SAMSUNG CD/DVD Burner 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model SH-222AL LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151235
22.99
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9R
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180
69.99
CASE: COOLER MASTER Storm Enforcer SGC-1000-KWN1 Black SECC / ABS Plastic ATX Mid Tower Computer Case ATX PS2 / EPS 12V (optional ) Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240&Tpk=storm%20enforcer
79.99 after rebate
I really like this case. I'm not sure if I am supposed to be going for a mid case or a full case. I would like a mid case if there is any chance of being able to fit 2 graphics cards in it at some point. I believe this case has a removable hard drive cage that can fit a long card or two. Need advice on this one.
PSU:Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049&cm_sp=DailyDeal-_-17-371-049-_-Homepage
64.99 after rebate
Any chance that this will be able to support 2 graphics cards? Im thinking the 560ti's
Graphics Card: EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
214.99 after rebate
I'd like to run these in SLI down the road if necessary.
Hard Drive:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
49.99
I would like to have a SSD boot drive but I am still doing some research on that. Might add that down the road if I cant find a cost effective solution right now. Feels like the SSD market is moving very rapidly right now so it might make sense for me to give it a few months.
Windows 7 64bit - 99.99
Monitor Resolution: not sure what monitor I want yet. I'll worry about that separately.
Current Total 972.91
Do I need a CPU cooler? Did I pick RAM that is compatible? Any advice on a small, reliable, inexpensive SSD boot drive? Anything I forgot and left out? Did I pick anything that just flat out sucks? Any and all advice is welcome and appreciated.
Thanks in advance!
-Will
Overclocking: Yes
219.99
149.99 after rebate
22.99
69.99
79.99 after rebate
64.99 after rebate
214.99 after rebate
49.99
Thanks in advance!
-Will
