First Build - Advice / Suggestions
Feb 28, 2018
4
Hey everyone, I am here to ask for suggestions or advice on my first gaming PC build. Here are the specs I've come up with so far:
- CPU: Intel Core i5-7500
- MOBO: MSI B250M Gaming Pro
- GPU: MSI GTX 1050 Ti Gaming X 4GB
- PSU: Cooler Master 550W 80+ Bronze
- RAM: 8GB
- Storage: 120GB SSD + 1TB 7200RPM HDD
- Case: Thermaltake Versa C23 TG RGB Edition
- WiFi: MSI Herald-AC Intel AC 8265 WiFi Card
Any advice or suggestions are very much appreciated
My Budget is $1200 AUD
Edit: Or should I jsut get a second hand GTX 970 for $200
Edit: The GPU is an MSI GTX 970 4G - No Warranty
Edit: How likely would a GTX 970 SLI not have been OC'd
http://cpu.userbenchmark.com/Compare/Intel-Core-i5-7500-vs-Intel-Core-i3-8100/3648vs3942
Same performance on the processor but gets you the latest tech with a high quality power supply, 16gb of memory, and larger SSD.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor ($154.50 @ Shopping Express)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard ($159.00 @ Umart)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($249.00 @ Shopping Express)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive ($99.00 @ Umart)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($58.50 @ Shopping Express)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card ($265.00 @ Centre Com)
Case: Thermaltake - Versa C23 TG RGB Edition ATX Mid Tower Case ($118.00 @ Shopping Express)
Power Supply: SeaSonic - FOCUS Gold 450W 80+ Gold Certified Semi-Modular ATX Power Supply ($99.00 @ PCCaseGear)
Total: $1202.00
Generated by PCPartPicker 2018-03-30 05:59 AEDT+1100
Would it be worth it if I got a second hand GTX 970 for $200 or a GTX 1050 Ti Brand New with Full Warranty
the 970 is much stronger
some manufacturers also tie warranty to the card itself, like msi and asus
so you can have both your cake and eat it too
depending on warranty term, and date of manufacture of the specific card
The GPU is an MSI GTX 970 4G and has no warranty anymore
