First Build almost done
Ashkit
4
So, i decided to build a gaming pc on a budget, heres my specs: CPU FX 6300 (supposed to overclock to around 4.5)
GPU: Sapphire R9 280X(Also planning on OC)
Motherboard:
Asus Sabertooth 990FX R2.0
RAM: Corsair vengeance 8GB
HDD: Seagate Barracuda 1T
Hyper 212 EVO Cpu cooler
And what i want to know is what kind of power supply do i need to support the build... i tought about buying the Cx600W at first but someone told me it was too weak, so now i am more inclined to the
XFX P1-750S-NLB9 Core Edition, please let me know what you think i should do..
Thanks
-Ashkit-
It's not that the Corsair CX600 is weak as in low powered (it has enough wattage), the CX models, Corsair's "Builder Series" are entry level PSU's that use cheaper components than a "stronger" PSU. The XFX 550 should be enough (unless considering X-Fire in the future, then 750W or higher)
