First build assistance.
Yagasinn
Hello, I am making my first budget build computer. I am wondering if all my parts are compatible and if I will run through any bottlenecks.
Processor: AMD A10-5800K APU Quad Core Processor Socket FM2 3.8GHZ 4MB 100W Retail Box
Motherboard: Gigabyte F2A88XM-D3H mATX FM2+ A88X DDR3 2PCI-E16 PCI-E1 PCI CrossFire SATA3 HDMI USB3 Motherboard
Ram: Patriot Viper Xtreme Series 4GB 1X4GB PC3-12800 DDR3-1600 11-11-11-24 1.5V Memory Kit
Hard Drive: Toshiba DT01ACA050 500GB SATA3 7200RPM 32MB Cache 3.5in Internal Hard Disk Drive HDD
Case & Power Supply: Logisys CS369BK ATX TOOL-LESS Gaming Case 480W Dual Fan Power Supply Water Cooling Ready - Black
CPU: AMD A8-7600 3.3GHz Quad-Core Processor ($92.95 @ SuperBiiz)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard ($52.99 @ SuperBiiz)
Memory: Mushkin Redline 8GB (2 x 4GB) DDR3-1866 Memory ($63.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($51.85 @ OutletPC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($29.98 @ OutletPC)
Power Supply: Corsair CSM 450W 80+ Gold Certified Semi-Modular ATX Power Supply ($26.99 @ Newegg)
Total: $318.74
Generated...
Get 2X4 gb of 1866mz ram. The integrated graphic processing unit of the 5800k will be bottle necked by single channel RAM.
The reason I said 1866 ram was because the igpu of the 5800k scales with the memory frequency of the ram. Therefore you can overclock said ram to 2133mz to get full potential of the igpu.
Also if you will be overclocking the 5800k I suggest going for the 6800k as it overclocks better.
If you are not overclocking then get the a8 7600. Performance is on par with the 6800k. It has newer architecture (28nm) and lower energy consumption than both the 6800k and 5800k.
I have a budget of 320$ D:
Total: $318.74
Generated by PCPartPicker 2014-12-30 23:06 EST-0500
