first build buying thermaltake armour lcs help!
john_smarty
148
i am building my new system right after Christmas. i was looking for some help i am buying a thermaltake Armour liquid cooling system from a friend.should i buy any more pumps tubing ect.
thanks,
john
You can get additional tubing from a local hardware store if needed. Old-fashioned hardware stores sell it by the foot. I'd build it with what you have and only add tubing if the pieces it came with aren't long enough, are moldy, or are missing.
so i dont have to buy i new pump because the old one isnt strong enough. i am cooling my vid. card, cpu, northbridge. thanks crashman i will get new tubing
That system isn't big enough to cool all that. Your looking at about $300+ with shipping for the standard CPu/NB/GPU loop.
I'll steer you to some more technical links, please spend a few days (DAYS) reading posts, searching, learning. Don't forget to look for your case with WC. Google your case and the word watercool or some combination of that. WC stuff is larger than you think, I know from experience. WC setups done right are awesome and almost silent.
Great place, not wayyy over the top with uber WC guys.
http://www.ocforums.com/index.php
Uber place, owned by one of the worlds winning OC guys in the world. Not a place to post or ask questions by noobs, but an awesome place to learn.
http://www.xtremesystems.org/forums/
Another good place to learn
http://www.overclock.net/water-cooling/
Great places to buy WC stuff
http://www.dangerden.com/index.php [...] e&Itemid=1
http://www.petrastechshop.com/
http://www.jab-tech.com/
Hope it helps, see ya in a few days, get edumacated!
yea the standard thermaltake cooling is crap, i bought a kandalf lcs and within 3 months replaced the whole loop, with on that cost me over £300, im wanting to sell the case with the watercooling if ure interested pm me and ill give u the details of the loop etc. oh and i only want £100 for it.
