I've finally made the decision to switch to pc, but I'm not too experienced with PC's. I'm needing to run games like Rainbow Six Siege, GTA V, Rocket League, and Battlefield 1 at 60+ FPS on a 1080p 144hz monitor on High-Max settings. How well will this do the job? My budget is around $900, willing to go a little higher than that, but if I'm planning to buy this around Christmas I could probably get many of these parts for a bit cheaper. I've created an Intel and AMD build. Which is better?
My AMD Build: https://pcpartpicker.com/user/TD_Falcon/saved/qTMpbv
My Intel Build: https://pcpartpicker.com/user/TD_Falcon/saved/#view=KQWXHx
-_-_-Questions-_-_-
How well will I be able to OC? Will I need a better CPU cooler or more case fans?
Is there any way I can use a Micro ATX mobo (to save money I can out into GPU) and still sufficiently OC?
Is there any way I can save money, rather than buying the same part for a higher price?
Is my intel or AMD build better (Solely for gaming)? Sorry if I start an uproar.
Thanks for reading and helping 😀
-_-_-Questions-_-_-
