First build - compatibility and overall review
Gabriel_47
Commendable
Jul 1, 2016
Hi!
I'm new to pc buildin and stuff. I studied and read about it for some months now, but because of college and work i had not had time to really go deep. So i only know the not-so-basic basic 😛
Approximate Purchase Date: this week or next
Budget Range: don't matter. Will buy in Brazil and the importation fees are expensive as f.
System Usage from Most to Least Important: Games and college stuff (statisc and phylogentic programs. Maybe PS)
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website for Parts: kabum(Br)
Overclocking: Maybe to no; I understand the idea, but don't have the time not want to spare to much though on this thing
SLI or Crossfire: is it needed?
Your Monitor Resolution: probably1440x900
Additional Comments: I wanna something that can work with games like The witcher III, GTA 5, CS go and BF1. I don't care for ultra high mega resolution, but i wanna use the "high" setting in the games xD
The planned assemble of pieces:
GPU Zotac Geforce GTX 970 4GB GDDR5 256-bit 3D Ready 4K Ready PCI-Express 3.0 ZT-90101-10P
CPU I5-6600 Skylake, Cache 6MB, 3,3GHZ (3.9Ghz Max Turbo), LGA1151, Intel HD Graphics 530 BX80662I56600
Motherboard GIGABYTE p/ Intel LGA 1151 ATX GA-H170-GAMING 3, DDR4, HDMI, AMP-UP,M.2,SATA Express,SATA 6Gb/s ,USB 3.0
Memory all alone in the moonligh... haha. ok, not funny. Logic Black Fire Series 8GB 2400Mhz DDR4 - LGCM8GF2400DDR4
HD
SSD Sandisk PLUS 2.5 SATA 3.0 (6 Gb/s) 240GB Leituras: 520MB/s e Gravações: 350MB/s - SDSSDA-240G-G25 and
HD WD SATA 3,5´ Blue PC 1TB 7200RPM 64MB Cache SATA 6.0Gb/s - WD10EZEX
PSU EVGA 500W 80 Plus White 100-W1-0500-KR
so... are they compatible? Is it ok for the purpose stated above? Overkill, or bottleneck for some piece? help? xDD
