Thorsten_2 :
Hello guys, I am going to build my first system, and am looking for some advice.
Approximate Purchase Date: Next month
Budget Range: 1200-2000
System Usage from Most to Least Important: Home, high dimensional data analytics, gaming
Are you buying a monitor: Yes
Do you need to buy OS: No, I am going to run Debian
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution:1920x1080, likely two screens with roughly 32 inch each
I was considering the following system:
https://pcpartpicker.com/list/YV86gL
What do you guys say? Does the system make sense? What is going to be the bottleneck in terms of performance?
First things first, THANK YOU for using the supplied template. It makes everything so much easier! As fo the build, I am not too sure of what high dimensional data analytics is, but from inference, it sounds like it would eat up CPU cores! Because of this I have configured a Ryzen based system, which has 8 cores and 16 threads, as opposed to 4 cores and 8 threads on the i7 side of things.
I am not sure if what your doing requires 32gb of RAM (though keep in mind that most tasks cannot benefit from more than 8 or 16gb of ram, and that for most tasks 32gb is completely overkill) but I left it in anyways.
I upgraded the GPU to a 1070, which will be far better at gaming and, perhaps more importantly, will bbe far superior in any hardware accelerated tasks.
All of these upgrades, of course, cost extra money, and so I stepped down the case, because lets bo honest, nobody needs a 570x (core P3 looks amazing though).
I have massively changed the storage because, although you mightn't know it yet, 250gb is not enough storage! I chose an X370 motherboard, not because it overclocks better (it doesn't), but because it supports SLI, so you can upgrade to dual 1070s easily!
The build:
PCPartPicker part list:
https://pcpartpicker.com/list/RJrdPs
Price breakdown by merchant: https://pcpartpicker.com/list/RJrdPs/by_merchant/
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor ($300.59 @ Amazon)
CPU Cooler: CRYORIG - H5 Universal 65.0 CFM CPU Cooler ($53.98 @ OutletPC)
Motherboard: MSI - X370 SLI PLUS ATX AM4 Motherboard ($128.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (1 x 16GB) DDR4-3200 Memory ($111.99 @ Newegg)
Storage: Western Digital - Blue 500GB 2.5" Solid State Drive ($139.99 @ Amazon)
Storage: Hitachi - Ultrastar 2TB 3.5" 7200RPM Internal Hard Drive ($56.50 @ Amazon)
Video Card: EVGA - GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card ($379.99 @ Newegg)
Case: Thermaltake - Core P3 SE ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Newegg)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($29.99 @ SuperBiiz)
Total: $1463.98
Generated by PCPartPicker 2017-05-27 02:48 EDT-0400
Hope this helps!
P.s. anything here can be changed. I hope everyone can take a look at this build and make their own suggestions, not just the OP
