First BUILD Corsair 570x need assistance . . .
Pittou
11
Greetings : ) so here is a link so far https://pcpartpicker.com/list/Z2MF9W
Acer Predator GN246HL - 24" 144Hz 1920x1080 1 ms buyed alredy
i will also buy 3 x Corsair HD120 rgb and rx570 comes with 3 x SL120rgb
wonder on the motherboard i want the pc for Gaming purpose i wonder what cooling system to choose : ( water or liquid . . i've seen Darkside ultra slim radiator which will fit nice in case . .. but with skylake i7-6700k and strix 1070 am not sure if i need watercooling cuz i dont think of overclocking soo am open up for advice Thanks : )
so i've made some changes this is the final build https://pcpartpicker.com/list/Z2MF9W
getting an AIO watercooler for your CPU is always a good idea no matter the load. if you never intend to overclock then dont buy a K processor. get an I7 7700 instead.
Any 240mm AIO cooler will work fine such as a corsair H100i
set it up on the top as exhaust and you're good to go
Hello, I'm currently building a PC very similar to yours. Was wondering what radiator you went with? I ordered the original corsair h100i, now second guessing it, now wounderinf about the corsair h105 but it's tad thicker. Just curious what you went with and how the is running!
Hello mate i went with NZXT Kraken x52 and my cpu dont goes over 50 C also its quiet !! soon i will upload pics with the finished build so far everything works fine and i changed GPU to 1080 Strix TI 11 gb
