first build could use review before buying
admiraltalbot
25
Im building my first semi budget gaming pc. I would like to play everything from total war to battlefield 4 and preferably with good settings.
I ordered a used 2gb powercolor 7850 gpu for 150 on ebay and I think ill go with
fx6300 cpu For 109$
Rosewill challenger case 46$
Diablotek 600watt psu 30$
Asus m5a97le mobo 90$
Kingston hyperx blu 8gigs 70$
Wd blue 1tb hdd 60$
What do you think? Any suggestions/criticism welcome since this is my first ever build and gaming pc. What kind of gameplay do you think I will get with this setup?
do NOT go with diablotek psu's
Tier 5 - Other than the units listed above for any of these brands, NOT RECOMMENDED. Replace ASAP if you have one.
A-TOP Technology
Apevia
APEX (SUPERCASE/ALLIED)
Aspire(Turbo Case)
ATADC
Athena Power
ATRIX
Broadway Com Corp
Coolmax
Deer
Diablotek<-------Do not get this.
Dynapower USA
Dynex
EagleTech
FOXCONN
FSP Everest
HEC Orion
Hiper Type-R
Huntkey
I-Star Computer Co. Ltd
In Win
JPAC COMPUTER
Just PC
Kingwin Inc.
Linkworld Electronics
Logisys Computer
MGE
MSI
NMEDIAPC
Norwood Micro/ CompUSA
NorthQ
NZXT
Okia
Powmax
Q-Tec
Raidmax
Rocketfish
Rosewill
SFC
Shuttle
Skyhawk
Spire Coolers
Star Micro
STARTECH
Thermaltake Purepower NP
Thermaltake Purepower RU
Thermaltake TR2 (and TR2-RX)
TOPOWER TOP
Ultra X-Connect
Ultra X2 >greater than 700 watt
Ultra LSP
Wintech
XION
YoungYear
Zebronics
Okay thanks for the heads up. What is the problem with that one? I selected it based on price and good reviews. This is why I put up this thread though to avoid buying the wrong thing. I havent bought it yet any suggestions for psu around the same price? Thanks again
Something that I always suggest to people is the addition of an SSD drive. If you have never experienced using one, it will blow your mind at how much faster they are. The performance bottleneck almost always occurs in the I/O part of your system, thus adding an SSD affects system performance as a whole. SSD's have seen a relatively sharp decline in price over the last several months. I would at least consider it. The one in this link is only 120GB, but it only costs 90 dollars! And the Samsung Evo is one of the best rated SSD's out there with very fast read/write performance. This SSD would really add to the performance of your proposed build.
http://www.amazon.com/Samsung-Electronics-EVO-Series-2-5-Inch-MZ-7TE120BW/dp/B00E3W15P0/ref=sr_1_2?ie=UTF8&qid=1394568674&sr=8-2&keywords=SSD
Ill look into that. It may have to be a future upgrade. Can you have an hdd and ssd in the same device? Would I have issues reloading windows on a new drive in the future due to microsoft policys?
You won't be able to get a decent PSU for under $50-60, but it's worth it.
Guess I was wrong...
You can certainly have an HDD and SSD in the same device. And if you purchase a windows license as a system builder you can transfer it from one PC to the next. Only when you buy a computer with Windows already installed do you run into the problem of Microsoft seeing the software as a pirated copy. I have run into this myself. Whenever you buy a computer with Windows already installed, it is forever linked to the motherboard that came in the PC. But if you build the system yourself, you don't have that problem.
Perfect. Not sure if I should go with a small ssd Now and then add more or go with a big hdd now and add a good ssd in future. Kingston digital has a 120 ssd for 70$ that is about all I can afford for now. It would be about 10 dollars more than the 1 tb hdd
