First build, couple of questions?
tomasandri
58
CPU - Intel Core i5-4570
Cooler - Corsair H100i
Motherboard - ASRock Fatal1ty Z97X Killer
Memory - Mushkin Blackline 2x4gb
Hard Drive - Seagate ST2000DM 2TB SATA
SSD - Toshiba MKNSSDCR 120GB
Graphics Card - Asus GeForce GTX 970 Strix
Power Supply - Corsair RM650 Modular PSU 80P Gold
Optical Drive - Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System - Windows 7 Home Premium SP1 (OEM) (64-bit)
Case - Corsair Obsidian 450D
Questions:
1) How will this build perform in newer games like AC4, BF4, Crysis 3, Skyrim, Far Cry 4 and such?
2) Will i have any bottlenecks?
Ignore the SSD. I already own it and I plan on getting another one later.
This build is a bit over my budget so I'll buy it in the next couple of months(like 2-3 months).
Not sure. Both for looks and just to keep it cool in general. And because I might over clock in the future :)
You are getting a non-overclock CPU with a Closed-Loop Water system and a Z97 motherboard. If you are planning to go overclocking, then get a 4690K. If you aren't going to overclock, then an air cooler (Hyper 212 EVO will be fine) or the stock cooler and a H97 motherboard will save you quite a bit of money.
Okay, I'll take a look at some H97 mboards and other coolers :)
You should probably get a more reliable manufacturer for the RAM and storage. Just to be safe...
Seagate does not make reliable hard drives and quite a lot of them fails within a year. Unless it's a SSHD in that case they do a pretty good job on.
Western Digital is what I would go for.
If you are planning to OC in the future then get a i5-4570k.
