This is my very first build and is mainly for gaming (Not sure if I will be overclocking anything because I've no experience with it at all) my budget is $1200 at the moment. I'd appreciate some other tips of advice's as well
___________________________________________________
OS-$139.99 ---Windows 8.1 Pro 64bit
CPU-$239.99 ---Intel Core i5-4690K Devil's Canyon Quad-Core 3.5GHz LGA 1150http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372
RAM-$86.99 ----G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (((I might go to 16 GB but not sure)))http://www.newegg.com/Product/Product.aspx?Item=N82E16820231689
HDD-$99.99 ----Seagate NAS HDD ST2000VN000 2TB 64MB Cachehttp://www.newegg.com/Product/Product.aspx?Item=N82E16822178391
PSU-$129.99 ---EVGA SuperNOVA 750 G2 220-G2-0750-XR 750W ATX12V 80+ Goldhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817438017
GPU-$159.99 ---SAPPHIRE DUAL-X 100365L Radeon R9 270 2GB 256-Bit GDDR5 (this depends on my budget might and might not get it)http://www.newegg.com/Product/Product.aspx?Item=N82E16814202090
MB-$124.99 ---ASRock Fatal1ty Z97 Killer LGA 1150 Intel Z97 Motherboardhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813157501
Case-$69.99 ----Thermaltake CA-1B5-00M1WN-00 Black SPCC ATX Mid Towerhttp://www.newegg.com/Product/Product.aspx?Item=N82E16811133254
Internal hardrive$19.99 ----ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burnerhttp://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Total: $1,071.91
Without GPU Total: 911.92
Also planning to get an aftermarket heatsink/fan ontop of the CPU, what would you guys recommend?
Total: $1,071.91
