[SOLVED] First build ever. No boot. "Ad" and "10" errors codes.
probiner
39
Hello
First time building a PC and not booting.
Here are the components
Mobo: ASUS PRIME X399-A
CPU: AMD Ryzen Threadripper 1950X
RAM: Corsair Vengeance RGB Pro - DDR4 8x 8Gb
GPU: INNO3D GEFORCE RTX 2080 Ti GAMING OC X3
SDD: Samsung 960 EVO MZ-V6E500BW
PSU: Seasonic Prime Ultra 1000 Gold
Case: Fractal Design Define R5
First of I had "Ad" error code and only one side of the RAM lighted up. https://i.imgur.com/eOL1OBn.jpg
Then I tried with just 2 sticks one on each side how the manual shows and I got "10" error code.
I took the CMOS battery out for a while between attempts.
The manual entries for the errors is not very helpful...
Anyone been through that?
Thanks
try all the one that ligh up in the a1 -b1-c1-d1 channel to see if they work also you did have plug in both 8 and 4 pins atx with the 24 pins on the board from psu
Thanks @scout_03
I reset the CPU and it worked after that. I'm guess there something in sequence when it comes to power supply and the CPU maybe was blocking. Had to be tucked in a bit better, I think the mobo doesn't help with all the extra space.
Cheers
