Today I finished putting together my very first build. It went smoothly; there were just a few times in which I had to take a step back, breathe, and find out what to do (after hopefully not doing any damage).
Eventually the time came when I would boot up my computer for the very first time. I ran through my checklist about what parts I had installed and whether or not they had their power and sure enough everything was good to go.
I plugged everything in and turned on the power button...things whirled to life but nothing showed on the screen. I didn't hear any BIOS beeps either.
The case fans were going, I could hear the harddrive come on, the CD drive blinked the green light on front a few times, the heatsink fan was spinning, everything seemed alright...except for the video. My video card is quite large so I knew something was amiss when I didn't even hear it or even feel it's exhaust exiting through the back of my system. I took off the cover and sure enough it was just sitting there, its fan still, doing absolutely nothing. The monitor stayed in sleep mode and blinked, at first, "No VGA Signal" then when I put it to DVI mode it said "No DVI Signal" and went back to sleep mode after giving me the above messages. I double checked the DVI cables connection to the monitor and the rear of my card and everything was as it should be.
Before making this post, I checked the thread here in the forum called "Read Before Asking About Boot Problems" and did everything applicable in that thread and still nothing seems to be working.
I took out the video card and reinserted it making sure it was situated properly, I made sure the RAM was in their slots and they were in there firmly and in what I'm assuming is the correct manner (I matched up the little notch, pressed down until the retention brackets came up). At all times I made sure to ground myself by touching the case. The only physical damage I can think that might have happened to it would just be accidentally grazing a component here and there when I misaligned something but I never forced anything. I even made sure to not get the connecting bits of devices dirty with oil from my hands.
I'm beginning to worry at this point. I saved up spent of my money for this build, and it's quite good if it'll only work, but now I'm wondering if I was too ambitious. My parents doubted I could do it and preferred that I would just by a computer with my hard-earned money but I thought differently so know I'm in quite the predicament...
At this point I just want to find out what the problem is exactly, whether it's simply the video card, the CPU, or the motherboard entirely, and don't want to do anything too drastic like try to return all the parts and get my money back (since I can't, given some of the items return policies). I'd still like to make this whole "DIY computer-building" work for me and I haven't given up all hope yet but it all this is a tad discouraging.
Anyways, my pieces that I have are
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Optical Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
Any help and suggestions concerning my next steps in this process would be greatly appreciated
If there's any more info you guys need, just let me know, by the way.
LSmoke
LSmoke
