Question First Build - First Post
Dec 11, 2019
First time posting - First time build
I wanna use the following parts:
Case: Lancool II
CPU: AMD Ryzen 9 3900X
Motherboard: Asus ROG Crosshair VIII Hero (WI-FI) ATX AM4 Motherboard
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory
Storage: Western Digital Black NVMe 500 GB M.2-2280 NVME Solid State Drive
Storage: Western Digital Black NVMe 1 TB M.2-2280 NVME Solid State Drive
Video Card: Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING
Power Supply: SeaSonic FOCUS Plus Gold 1000 W 80+ Gold Certified Fully Modular Fans: Corsair LL120RGB LED (Three Fans With Lighting Node PRO) 43.25 CFM 120 mm Fans
Fans: Corsair LL140 RGB LED (TwoFans With Lighting Node PRO) 51.5 CFM 140 mm Fans
Fan Hub: Corsair Commander Pro
I will be using the cpu stock cooler and also the 3 fans that come with my case.
I want to set it up something like:
3x stock fans are in the front pulling air into the case,
1x 120mm exhaust out the back
2x 140mm exhaust out the top
The case is setup so I can have additional fans on the bottom.
First question: If I setup 2x 120mm on the bottom, would I set it up as an intake or exhaust?
If I use all the fans that came with the case plus the additional 5x I was gonna use, will there be a problem with this many fans?
Second question: Is there anyone who could/would point me in the right direction as far as connecting these items(all the fans WITH the stock cooler) up in the right spots?
Thank you in advance!
