Hey everyone,
So I started building my first PC tonight. I got completed most of the wiring and installed everything in the case, with the exception of my GPU (R9 270). Problem is, the GPU will not fit into the PCI-E slot on my Asrock H97 Pro4 motherboard. It seems as though PCI slot is off by about 1mm.
Here is a picture so you can see what I mean... http://imgur.com/YxISqy6
Kind of hard to see, hopefully you can make it out. I can't seem to push the GPU back any closer to the case to make it fit into the slot. Seems to me like something isn't aligned properly, either on the motherboard or GPU.
Would greatly appreciated some help! Pretty bummed out about this since the build was going pretty good up until this point.
...Thanks!
...Thanks!
