Question First Build Help: MSI B450 max 2 not detecting WD sn850 m.2
4
Hey all. I dove into my first ever PC build with some guidance from friends. My motherboard is not detecting the m.2 drive in bios so I can't move forward. The MB recognizes my hand-me-down SATA optical drive, but I don't have any other drives to test out.
MB: MSI B450 Tomahawk Max II w/ Ryzen 5 3600
m.2: WD sn850 500gb
Can anyone help this noob out?
Mar 25, 2021
4
Likely you have plugged the optical drive into a reserved SATA slot which shares bandwidth with the M.2 slot. Move the optical drive (or unplug just to test) to another SATA port.
Negative. I am not using the reserved ports (5 and 6), and the problem exists even after completely unplugging the sata drive.
Mar 25, 2021
4
Hmm, usually see large warnings about updating the BIOS too far when using an older CPU. Those recent BIOS are for the 5000 series.
Yeah, not sure on this one. Could be a bad drive or motherboard.
Would flashing to an older bios be worth trying? Without having another m.2 drive, any suggestions on how to test the board slot? Or test the m.2 card without another board? I could check if a repair shop could at least test my drive to see if it works.
Troubleshooting things like this is why I was always too nervous to build a machine myself.
Eximo
Ambassador
I usually point people to repair shops when they have new components that don't seem to work. Really the only way unless you have friends who have recently built computers and want to take on the risk.
Nice shop people might even diagnose for free on a slow day.
rakib.shahid.123
11
m.2: WD sn850 500gb
I don't mean to revive a dead thread, but I'm having a very similar issue and can't find anything online. Did you ever solve your issue? I also have an SN850 (1tb) and my motherboard (Asrock b450 pro4 + ryzen 7 3700x) isn't recognizing it either
