I'm planning to put together my fist PC. I have been spending a lot of time searching for parts and this is what I came up with, but I am not really sure whether those parts work togehter well. Here are the parts.
CPU: Intel 4670k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
GPU: gigabyte gtx 770 http://www.newegg.com/Product/Product.aspx?Item=N82E16814125463&cm_re=gtx_770-_-14-125-463-_-Product
Motherboard: MSI z97 Gaming 5 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770&cm_re=msi_gaming_5-_-13-130-770-_-Product
Case: orsair Carbide 300 http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011&cm_re=corsair_carbide-_-11-139-011-_-Product
PSU: Corsair RM650 http://www.newegg.com/Product/Product.aspx?Item=9SIA24G1E34205&cm_re=corsair_650w-_-17C-0010-00011-_-Product
Other parts I dont worry about. Maybe anyone has similar build or could give me advice about those parts and maybe if something should be changed. Im not looking to do much overcloking in the start, but probably later. And probably add one GPU when computer stars lacking power later on. Thanks in advance
