First Build, Help Needed
shyheim
82
Hey guys, looking to make my first build. Won't be just for games, but it will be for games also, so quad core and a nice graphics card is a must. So far, I have...
Don't Need: Monitor (have an old Viewsonic), keyboard, mouse, sound card, speakers
GPU: Geforce 275
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130479
CPU: Intel i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
PSU: CORSAIR CMPSU-650TX 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HDD: Western Digital Black 640 GB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Mobo: Not Sure...
Case: Not Sure...
RAM: OCZ Gold DDR3 3x2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
I'll be using this rig for gaming so I don't want to lag (will be trying Mortal Online probably) and video editing.
How does the build look so far? Any suggestions for a case and mobo? Think I should go with a bigger PSU?
Thanks for your help 😀
EDIT
Will be overclocking! So fan help could also be helpful.
Monitor resolution will 1920x1200
The budget is roughly $1200
I will be hoping to run SLI or crossfire in the future when I can afford a second card.
swap the GTX 275 for an ati 4890, it's ~$50 cheaper and performs just as well if not better.
the PSU is fine.
get a P6T motherboard, anything above that isn't worth it for your needs.
for a case, get an antec 300 and a couple of 120mm fans or a coolermaster 690 and a couple of 120mm fans.
Monitor resolution will 1920x1200, the budget is roughly $1200, and I will be hoping to run SLI or crossfire in the future when I can afford a second card.
Would the ati 4890 really trump the GTX 275 in most cases? I have heard a dizzying amount of chatter on both sides of that argument.
