first build help please
Dorksouls
50
is this everything I will need:https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=523314&action=wish_lists
and will it work and be able to achieve 60 fps on games like rust on medium+ settings?
thank you for your help
Everything is good there for some nice 1080p gaming at good settings. I`d avoid the G1 960 too only because of the price to performance gain which is not much and the ram could down to 8gb, which would be fine. Normally I`d agree, but these days I`d say just get the 16gb now and get it over with.
Further more, good build!
That setup will give you more than medium settings at 1080p. You should hit 60fps on lots of games even at High, and some Ultra. If I might make a suggestion, 2x4gb RAM is fine too. The money you save you could put towards a better mobo with more features. Otherwise, build is solid.
i'm wondering about the gtx 960 i've chosen compared to the other models/brands have I chosen right?
You could just get the Windforce instead. It is 20 less. But I'd definitely get the 4gb version, not 2gb.
rather get the more powerful one but thanks
