Hello,
Hello,
i am going to build a new computer, the one i bought that was pre built on Newegg just isnt cutting it anymore, things are getting heat damaged, ect ect... plus i heard you can get exactly what you want for less than a pre built of that caliber so here i go:
AMD 7870 2GB GHz Edition (hopefully Xfire soon)
ASUS Crosshair V formula 990FX MOBO
AMD BullDozer 8150FX 8-core CPU
Gskill Ripjaws X-series 1600Mhz DDR5 RAM (4x4)
Corsair Force Series GT 120GB Solid State Drive
Corsair Enthusiast Series TX950 80Plus 950W PSU
Corsair Carbide Series 500R Mid Tower case
Corsair Hydro Series H80 HP liquid CPU cooler
I'd appreciate input on what may or may not work good or at all with eachother. or if the case is bad for this setup ect, this my first build and i wanna do it right the first time haha, then comes the installation but anyways, Thanks in Advance (1800-2000USD budget)
Hello,
