First Build Help!
From what I see you are missing an OS (Unless you are planing to run linux or have windows already) and a disk drive. That will run you about another $110. $90 for windows and $20 for the disk drive.
I'm going to get another 4gb soon, money is a bit of a push the now so 4gb will be fine for a couple months.
Thanks though!
hope you have a monitor already....
apart from that, when you are building a gaming pc...go with a 8gb ram kit instead of a single 4gb module.
also in case you would like to oc your processor, you will need an after market cpu cooler.
as for the psu, i would highly recommend a 600W psu instead of a 500W
Looks pretty good, I would upgrade to a 8GB kit (2x4GB), and the R9-270X would be a good upgrade for a small cost. The Corsair CX PSUs are not very good, I would suggest the XFX 550 watt PSU, it is made by SeaSonic and a much more reliable option.
