First build - i7 920 - cooling/general advice needed
samschu
4
APPROXIMATE PURCHASE DATE: August 5th-17th
BUDGET RANGE: 1200-1500
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Movies, Internet...
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS,
PREFERRED WEBSITE(S) FOR PARTS: newegg
PARTS PREFERENCES:
intel core i7 920 d0 stepping:
https://www.antaresdigital.com/customer/product.php?productid=16135&cat=0&page=1
the rest:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=15941327
Current Price: $1370.53 (including rebates, shipping, tax)
OVERCLOCKING: Yes SLI OR CROSSFIRE: SLI in a couple months.
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS: I will be using Windows 7 RC for now.
Also, because I want to get d0 stepping I think I am buying the i7 920 from antaresdigital.
For now, I would like to know if I need more cooling.... extra fans? Other than that... any advice will be helpful! Thanks.
I really don't know... I guess I just figured more is better? That is why I am asking for advice.
Under what conditions will 12gb show improvement over 6gb?
^ The list of components are good, but you can save money with these changes, without loosing much of features or performance...
1. Check out this mobo...has sufficient BIOS options for a very good overclock and has good layout...
EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188049
2. RAM - You can better specs RAM for that price...
OCZ Platinum
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
Or if you want easy setup of the RAM settings, then get this RAM with XMP profiles...
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
3. You might require 850W for a GTX 260 SLI...You can drop to Corsair 750TX...It is even suffice for GTX 275 SLI/ HD 4890 Crossfire...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Apart from these the other components you have chosen are very good...
Here is an another good CPU cooler alternative...
Scythe Mugen 2...
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093
And just a suggestion...For the price of that GTX 260, you can get a HD 4890 for about $10 more...But not much of a difference for that resolution though...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127427
And GTX 260 SLI is not a good option to consider as newer Direct 11 cards are coming...So that time, instead of buying another GTX, invest in them...
Hope this helps...
My point is that before you start chosing parts or throwing money away you could read a few of the articles on this web site
Up there is a tab called ARTICLES
click on it and then browse to MEMORY
anything there that might offer some insights into the kind of set up you want to build?
Very helpful guys. gkay: I was thinking the evga 132-BL-E758-A1 because of the lifetime warranty. Will look into your RAM/PSU/Cooling suggestions.
Thank you, I will do that.
Check out this Combo at NewEgg on your selection of Mobo/Graphic card that will save you an additional $18.00.
1. EVGA 896-P3-1255-AR: $184.99
2. EVGA 132-BL-E758-A1: $294.99
Combo Discount: -$18.00
Combo Price: $461.98
$30.00 Mail-In Rebate
$20.00 Mail-In Rebate
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.209580
Since you are going with the Antec 1200 Case you will need this 8-pin Power Extesion cable for Bottom mounted Psu cases. Otherwise you will have to run that cable across the length of mobo.
1ST PC CORP. 12" 8-pin EPS extension cable Model CB-8M-8F - Retail $7.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16812706004
