When are you purchasing the parts ? Less than one month.
What is your budget ? About ¥8,000 (CNY) About $1,300. Feel free to use dollars. I don't expect you guys to use Chinese Yuan.
What are your needs ? I'd like a good gaming computer what will remain relevant for as long as possible.
Your expectations from the PC : I'd like it to run quietly and have dual monitor, and HDMI support.
Your location : I'm in Shenzhen, China (on the mainland, just across the border from Hong Kong)
Your preferred sellers/websites : I will buy locally.
Your part choices : I'm looking for longevity. It seems Corsair is making good PSUs and RAM. Western Digital Cavar Black seems like a good choice for an HDD, though, I'd like an SDD.
Are you upgrading or taking parts from any older PC/laptop ? No.
Do you plan to upgrade this PC ? Yes.
Do you need a OS or any other software ? Yes. I'm currently using a netbook running XP. I'd like to get Windows 8 for its speed and stability, though, I must admit, I have some trepidation about game compatibility. It should work with anything that runs on 7, but I've just read that the 8.1 update fudged things up for some people.
Do you need any Monitor ? No. I'll probably upgrade later.
Do you need any peripheral ? No.
Any other notes : none.
