Hello, I am going to attempt my first PC build in over 10 years (last time i built a PC Windows ME was just released). I have 2 dell computers that I purchased in 2001 that have served me well (apparently I am lucky) and I now am finally looking to get a new computer. I really don't have a fixed budget, I just want something that will fit my needs and not be overkill. After doing research for about a month and picking over the insane amount of information I have finally decided to pick my build, so here it goes. And I apologize if some things are just utterly ridiculous.
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Item #: N82E16827135204
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
CORSAIR CMPSU-750TX 750W ATX12V v2.2 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ...
Item #: N82E16817139006
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2A1600C9
Item #: N82E16820145324
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145324
ASUS SABERTOOTH P67 (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131702
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131702
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
Item #: N82E16819115070
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Microsoft Windows 7 Professional SP1 64-bit - OEM
Item #: N82E16832116992
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Item #: N82E16835103065
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
I haven't decided on a tower or a graphics card, any recommendations?
Sad to say I will not be using this computer for gaming. I will be using this computer for music production. I will be running Ableton 8. Inside Ableton 8 I will be running secondary programs like NI Massive and Zebra 2 (they run inside Ableton, but are stand alone programs as well.) I would like to have a dual monitor setup as I will also be doing some video production.
Any thoughts, suggestions, corrections, and criticism would be greatly appreciated.
So far the build it at $914
Thank you,
Eric
Thank you,
Eric
