Hi, thanks for taking a look! I want to know if this all adds up and maybe if there are some better parts choices to go with. Also I have some questions on display options but first take a look at what I got. (sorry couldn't get the HTML links to work)
x 2 Graphics Card for CrossFire
GPU: XFX Core Edition FX-785A-CNL4 Radeon HD 7850 $149.99
CPU: Intel Core i5-4440 Haswell 3.1GHz $199.99
MOBO: ASUS Z87-A LGA 1150 Intel $139.99
RAM: CrucialBallistix Sport 8GB (2 x 4GB) $69.99
PSU: EVGA SuperNOVA NEX 650 $99.99
Case: Cooler Master HAF 912 $59.99
I heard this had good ventilation and its cheap.
DVD: ASUS 24X DVD Burner $19.99
Fans: Not sure need quick input. My guess is 2 x 120mm added to what comes with the case.
Alrdy have a SSD, HDD, and Windows 7 home premium.
This computer's sole purpose is to run Final Fantasy XIV A Realm Reborn but read further. (link to system requirements at the end)
The issue I have is I would like to know how far I can go with monitors and resolution without impacting the quality of game play to greatly. I'm probably crazy but what I really want is a 3 monitor extended display though I have no idea what this graphics card pair will do in regards to multiple display and high resolutions. I am a little worried the processor might not be enough as well. I can make some improvements but Idk about getting a processor more expensive than this one. I am open to all suggestions but I do not want to run any resolution on the main monitor that would be under 1920 x 1080. Thank you for reading and I hope to hear your input!
Here's the link to the system requirements.
http://www.ffxivinfo.com/systemreqs.php
