First Build: Monitor not connecting properly
Michael_z
6
This is my first computer build and I am using the following components:
Intel 4790k i7 processor
512gb samsung evo 850 SSD
2x8gb ram sticks from rip jaws
corsair cx 430m power supply
geforce gt 610 video card
MSI H81M-P33 mini atx motherboard
Forgot what the case is but everything fits/works with it
Please nobody say anything about the bad video card with good processor, I'm not using this computer for gaming.
Anyways so the particular motherboard I bought comes with an extremely bad manual and I couldn't find anything good online, I've attached basically everything and hooked them up to the motherboard/power supply and when I turn on the power the fans start spinning and lights turn on and everything starts to work.
Problem is the monitor/getting that to work. I tried hooking it up with VGA and also HDMI and neither seems to work it just says analog on the monitor and I've tried pressing keys etc.
I'm 99% sure I did something wrong but honestly have no idea what, any ideas?
Also can anybody double check for me that the parts are all compatible?
Thank you
Maybe your motherboard need a bios uldate to run the 4790k. You can check what bios version you have on the mobo itself and compare it to what support the 4790k on gigabytes site for that mobo.
On a side not why did you buy an overclockable cpu witha b 51mobo?
All the fans (CPU fan, GPU fan, and external fan) start spinning and the LED turns on, and yea I've tried that
