First build motherboard and GPU, PSU questions
selimexotic
23
Hello,
Im building my first computer and am on a budget. I have selected a AMD Phenom 2 x4 965 black edition processor. Asrock 970 extreme 4 or A75 pro 4 MB. I have 8 gigs of DDR3 and a snow edition Thermal take tower. Here are the links.
Processor
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5312392&csid=_61
MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157316
MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
Case
http://www.thermaltake.com/products-model.aspx?id=C_00001841
Also i have a new DVD drive. And havent purchased the HDD yet/ My question is what is a good affordable PSU under 100.00 that can be bottom mounted. Im worried the cables wont reach the MB. My other question is will i need to buy a GPU? One of the motherboards has a VGA porn does that mean i dont? If i do what would be a good GPu to buy under 150.00 that wont be worse then the processor i have. Im sorry if i didnt format this right this is my first post and first build and am totally clueless.
ko888
16,530
8
97,165
3,087
The AMD Phenom II X4 965 Black Edition is a Socket AM3 processor.
The ASRock A75 PRO4/MVP is a Socket FM1 motherboard so you can eliminate it from your choice.
You mention "Asrock 970 extreme 4" but the link you've provided is for the ASRock 970 Extreme3 so which one is it?
There is no onboard video on either the ASRock 970 Extreme3 or the ASRock 970 Extreme4 so you'll have to purchase a discrete graphics card.
For a GPU I would recommend the SAPPHIRE Radeon HD 6870 for $159.99 ($149.99 after $10.00 rebate).
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
For a system using a single Radeon HD 6870 graphics card AMD specifies a minimum of a 500 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 30 Amps or greater and have at least two 6-pin PCI Express supplementary power connectors.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Combined Continuous Power/Current Available on the +12V Rail(s) @ 50°C ambient temperature, is the most important factor.
The PC Power and Cooling Silencer Mk III 500W Modular (PPCMK3S500) for $79.99 ($59.99 after $20.00 rebate), with its combined +12 Volt continuous current rating of 38 Amps and with two (6+2)-pin PCI Express supplementary power connectors, is more than sufficient to power your system configuration with a single Radeon HD 6870.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703035
selimexotic
23
I meant Extreme 3 sorry. Thanks for the help. Ive read reports of people having problems with their PSU being bottom mounted and not reaching the MB.
ko888
16,530
8
97,165
3,087
I have a SilverStone case that has a bottom mount PSU.
The only cable that I found that may have a length problem is the 8-pin CPU power cable because of the location of the 8-pin CPU power connector on the motherboard.
I have a Corsair HX750 which has slightly longer than cables than most of the competitor PSUs.
You can also buy extension cables, if you need to, that will solve those problems.
xmetallik
19
don;t worry too much about that, most of them these days are, if you are that worried you can also but cable extenders, I am using Bitfenix Alchamy extenders in my build, they look really nice, individual sleeved and avaible in black, red, green, orange, silver, white and blue, http://www.pccasegear.com/index.php?main_page=index&cPath=19_1251
xmetallik
19
xmetallik
19
dont worry too much about that, most of them these days are, If you are still worried you can buy extenders, I am using BItfenix Alchamy indivudual sleeved extenders, they are aviable in red, black, white, green, blue, sliver and orange http://www.pccasegear.com/index.php?main_page=index&cPath=19_1251
ko888
16,530
8
97,165
3,087
Go to the reply you want to delete and perform the following for each reply you want deleted:
Similar threads
