First Build Need Advice :)
nozdor
Guest
Feb 23, 2010
4
Approximate Purchase Date: Most probably by the end of September, early October at the latest.
Budget Range: $900 tops.
System Usage from Most to Least Important: gaming (BF3, diablo 3, witcher 2, etc.)
Parts Not Required: I already have a Thermalthake 750W modular power supply that I bought couple of months ago to start my new build but had to delay it due to masters degree getting crazy 😛, keyboard, mouse, monitor, speakers.
Preferred Website(s) for Parts: newegg.com or amazon.com.
Country of Origin: U.S.
Parts Preferences: I would like an AMD machine (with AM3+ socket) since it appears to be cheaper, but suggestions are welcome of course.
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments: None
Include a list of any parts you have already selected with descriptively labeled links for parts.
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
SAPPHIRE Vapor-X 100314VXSR Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102925
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Western Digital Caviar Black 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
ASUS M5A99X EVO AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Thanks in advance guys,
Noz.
