First Build, Need Help - $400 Budget Gaming PC
tehflyingknee
8
APPROXIMATE PURCHASE DATE: Next week; Payday BUDGET RANGE: $500 and under ($400-450 preferable)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Web Browsing, Multimedia
PARTS NOT REQUIRED: OS, Monitor, Speakers, Keyboard, Mouse, Hard Drive, DVD Drive, Aftermarket Cooler
PREFERRED WEBSITE(S) FOR PARTS: None; I chose all my parts from Newegg but I'll buy from anywhere offering the best bang for the buck.
PARTS PREFERENCES: None
OVERCLOCKING: Yes, but not to a serious degree, experimentation mainly SLI OR CROSSFIRE: No
MONITOR RESOLUTION:
1024x768
ADDITIONAL COMMENTS: Is this functional? I'm trying to be as budget as possible and despite what I've heard about getting a good namebrand PSU, will the 585W one that comes with the case be enough for the 4870?
Also, someone told me the RAM is incompatible with the chipset of the mobo's chipset because it's 2.1V and the G31 chipset supports only 1.8V. He recommended:
OCZ Blade Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227453
Despite researching on google, I could find nothing to support what he said, so is this true
THE BUILD:
CPU/PROCESSOR: Intel Pentium E6300 Wolfdale 2.8GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116091
MOTHERBOARD: ASUS P5KPL-CM LGA 775 Intel G31 Micro ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131288
GPU/VIDEO CARD: SAPPHIRE 100259L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102810
CASE:
HEC 6C28BBX585 Black Steel ATX Mid Tower Computer Case 585W Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121002
RAM: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
PSU: 585W - See "Case"
Combo Deals: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.196220 - for case/gpu
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.197650 for mobo/cpu
Grand Total: $415.15 (without rebates)
So my main questions are: Is this build functional? What specs will this build be able to play Crysis at? Should I just buy some higher quality items in the areas of the case and PSU? Also, I only chose the mobo because it came with the CPU in a combo deal, any better suggestions would be great.
Just please, give me any help you can while keeping the price in the $400 to $500 range.
Based on your resolution I think the card is overkill.
I recommend going with a 4850 to save cash, then choose a different case/psu.
If you buy a strong name brand PSU now, then in a year or six months or whenever you have the money/desire you can upgrade your monitor/gpu and not have to worry.
Go AMD and save some major cash and use it for the video card.
This rig will take a poop (for games, anyways) on the build you had lined up.
COOLER MASTER ELITE 335 RC-335-KKN1-GP Black ATX Mid Tower Computer Case - $50, $10 MIR, Free Ship
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Power Supply - $60, $10 MIR
ASUS M2A74-AM AM3/AM2+/AM2 AMD 740G Micro ATX AMD Motherboard - $60
AMD Athlon 64 X2 5400 Brisbane 2.8GHz Socket AM2 65W Dual-Core - ADO5400DSWOF - $59, Free Ship
OCZ Blade Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 - OCZ2B800C44GK - $47, $10 MIR
HIS Hightech H489F1GP Radeon HD 4890 1GB Video Card - $220, $20 MIR
Total: $496, $50 MIR
If you're willing to do this MIRs, this rig falls right into the high level of your budget...
Not to mention, this case has free shipping which will lower your shipping costs by $20... at least
Even at lower resolutions like 1024x768, the 4890 is far better than the 4870.
4870: Crysis Warhead - 1024x768 4xAA 8xAF - 34.8 fps
4890: Crysis Warhead - 1024x768 4xAA 8xAF - 41.1 fps
Thanks for input, I think if I did downgrade on the GPU from a 4870 I would choose a 9800GTX+ rather than a 4850 based on reviews I've read on newegg, but idk that build does sound pretty good. And I know Corsair is good but could that 400W power supply really handle a 4890? And the reason I chose an Intel build was because from every source I've read AMD cannot even compete with Intel in the dual-core processor range although their new quad-cores are becoming competitive.
once ur building a budget pc its amd or its a waste of money when you can afford to spend 1000+ for a cpu with 8 threads that only industrial computing apps can take full advantage of then intel is a must. even ill tell you that
SILVERSTONE SUGO SG02 - $69.99
Intel Pentium E5200 - $69.99
CORSAIR 550VX / GIGABYTE GA-G31M-ES2L - $142.98
G.SKILL 4GB DDR2 800 - $47.99
XFX GTX 260 Core 216 - $184.99
Total: $515.94 | After Rebates: $455.94
This is getting the most out of your money while only going $15 over budget, which actually won't exist after you get your rebates. Since you are gaming you want a strong graphics card.. The XFX GTX 260 is on sale with rebates and two games, why not? I also found a sweet combo on a 550VX and GA-G31M-ES2L.
The mobo is mATX so naturally I went to find a nice case to fit it, I already had one in mind. The SG02 is a beautiful micro-atx case that fits a regular sized psu and video card.
Last to do was ram, it was easy.. G.SKILL has a strong quality and low prices, if you want some 1066 ram, spend about $10 more for the same brand.
Any objections to this build? :)
dude above me good intel build but just to give op the option, here is me
amd
Gamers case with top exaust $55 5eggs
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
psu and adapter $83 5eggs
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
http://www.newegg.com/Product/Product.aspx?Item=N82E16812706014
Board $53
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128383
Cpu $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103211
Ram $27 5 eggs
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134488
Gcard 5eggs $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133270
I didnt add shipping but i didnt minus rebates. total cost
$453
good luck and remember when people say amd cant keep up with intel it dosent mean all intels are better than all amds it just means that amds top dog cant bark as loud as intels top dog but if your buying a dalmatian why the hell would you worry about whose pitbull wins?
i put 2 gigs only because im assuming hes going to be running xp but 4 gigs wont be much more expensive
As far as Intel vs AMD, let's say it this way, I've been working on computers for probably 10-11 years, I've got my Bachelor's for IT, and I've got my Apple certification, but I have always used AMD, reason being I can't justify the price differences between the chips, because personally I work hard for my money and can't see throwing say 50 bucks away on the intel chip that may be 5% better. But so far I've not been dissapointed by AMD. As others said, if you have money to spend, thats one thing, but when you are on a budget you want the most balanced system you can, there is no sense in having a gaming system with a faster processor but not have as much memory or have a bad video card. Better to have a worse processor, but have more ram and better video, etc.
