Approximate Purchase Date: Maybe a couple months, hopefully sooner
Budget Range: Approx. $1500 rebates/discounts/shipping included
System Usage from Most to Least Important: Gaming>Movies>School
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Websites for Parts: newegg.com, ncix.com, Amazon.com, microcenter.com(last option)
Parts Preferences: Intel Build, Open to ideas
Overclocking: Maybe
SLI or Crossfire: Maybe
PROCESSOR (CPU)-
Intel Core i7-2700K Sandy Bridge 3.5 GHz (3.9GHz Turbo) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Prod [...] 6819115095
MOTHERBOARD-
ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s
http://www.amazon.com/dp/B007G51UV0/?tag=pcpapi-20
RAM-
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL10D-16GBXL
http://www.newegg.com/Product/Prod [...] 6820231489
HARDDRIVE-
Western Digital WD RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822136697
VIDEO CARD-
GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Prod [...] 6814125418
POWER SUPPLY-
Rosewill LIGHTNING Series LIGHTNING-800 800W Continuous http://www.newegg.com/Product/Prod [...] llFullInfo
CPU COOLER-
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Prod [...] 38566&SID=
COMPUTER MONITOR
Asus VE228H 21.5-Inch Full-HD LED Monitor with Integrated Speakers http://www.amazon.com/dp/B00413PHDM/?tag=pcpapi-20
OR
COMPUTER MONITOR (HOLIDAY SPECIAL)
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) W/Speakers
http://www.newegg.com/Product/Prod [...] 6824236052
OPERATING SYSTEM
Microsoft Windows 7 Home Premium SP1 64-bit – OEM
http://www.newegg.com/Product/Prod [...] 6832116986
You can also find the build @ http://pcpartpicker.com/p/rdqs
I only plan on getting one monitor for now!
I have very limited knowledge when it comes to building, but I have learned a lot from these forums. I was just hoping to get some input, and I'm open to anything.I was also curious as to the cables that are going to be needed. I have seen it is hit or miss on getting them with the drives/mobos/etc... Thanks for all your help!
Overclocking: Maybe
PROCESSOR (CPU)-
MOTHERBOARD-
RAM-
HARDDRIVE-
VIDEO CARD-
POWER SUPPLY-
CPU COOLER-
COMPUTER MONITOR
OR
OPERATING SYSTEM
thank you so much for your help. I definitely needed it.
