First Build Need Help Compatibility
ricestrike
8
I am building my first PC and it is going not too well, what I feared happened, and now I need help. So it turns out the new CPU I got sent from Tiger Direct is incompatible with the board I have now and Im getting a second confirmation from you guys.
The board I have is the Biostar N68S3B Geforce Board
The CPU Im being shipped is AMD Phenom II X4 840
Can I get a reply ASAP to see if I have to cancel the order and give the staff a "one two" for recommending a CPU that is incompatible
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7225660&CatId=4431
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7144823&CatId=4296
If it is incompatible can I get a recommendation of a good CPU that is with this motherboard?
Regards, Rice
