Approximate Purchase Date: this month or next month
Budget Range: ~1500$
System Usage from Most to Least Important: Battlefield 3, Skyrim, Rage,general gaming, web browsing, etc
Parts Not Required: mouse and keyboard, os
Preferred Website(s) for Parts: Newegg.ca
Country of Origin: Canada
Parts Preferences: none
Overclocking: maybe
[strike]SLI or[/strike] Crossfire: yes, eventually
Monitor Resolution: not sure, could someone tell me ?: http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236052
Hey guys, I will be building a new computer pretty soon and I'd appreciate some advice as my knowledge about gaming pcs is not the greatest. First of all, I will post the parts I want to buy. I'd also like to know if there are better alternatives or any incompatibilities with some parts. As for the asssembling, I'll be fine since ive done it a couple times.
Parts
Monitor:
Tower:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119213
PSU: (750 watts enough for crossfire?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139010
MOBO:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131646&Tpk=asus%20m4a88td-v%20evo%2fusb3
Ram:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231352
Processor: (Overkill?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115070
Graphics Card: (will crossfire eventually. Does the company make a difference or are they all the same? ie: xfx, power color, asus, msi, gigabyte if not witch is best)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121430
DVD drive:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
HDD: (Better,more reliable alternatives?)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136073
Price total: app. 1400-1500$
Can I green light it or am I missing parts/incompatibilities with my build? I more than welcome you guys to suggest me better alternatives, thanks.
Overclocking: maybe
Parts
Monitor:
Tower:
MOBO:
Ram:
DVD drive:
