Approximate Purchase Date: This Week most likely
Budget Range: 600-650 +OS
System Usage from Most to Least Important: Game design, Gaming
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg, but if there is somewhere I can buy these parts cheaper, tell me!
Parts Preferences: My build is AMD based
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: Here's my build so far
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236203
CPU/Motherboard: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1420834
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121772
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148540
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
+a 750 PSU that I already bought (on accident, long story)
I have a few questions:
Would I get more bang for my buck with a http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004 for my GPU?
Will I need to buy a wireless card? My modem is downstairs so it wouldn't really be an option to run a cord all the way up. Is there someway I can maybe put an additional router in my room and connect my computer through that?
Also, what copy of Windows should I get? 8 or 7? Home premium? ?
Overclocking: Maybe
